Ricoh Aficio 3260c Dropping Black Toner
  • mkelly1967
    • Dec 2012
    • 25
    [CQ] Ricoh Aficio 3260c Dropping Black Toner
    Hello all!! I have a Ricoh Aficio 3260c that is dropping black toner. When you look at the transfer unit there is a build up all along where the imaging unit sits. It puts black spots on the copies/prints. I have replaced the developer, drum, blade and cleaning brush unit. Any help would be appreciated. Thanks!!!
    • 37532
    Re: Ricoh Aficio 3260c Dropping Black Toner
    When you say that you have replaced the developer, does that mean just the developer or the etire development unit? Recomended service life of the development unit is 3M. Considering the age of the machine you might want to replace the development unit if it hasn't been replaced before. Check to see if there is black toner scattered onto any of the other PCDUs that could be dropping onto the ITB. Check anything above the paper path that could be contaminated with black toner that can fall onto the paper.
    • turbojetboy
      • Aug 2009
      • 279
      Does it look like it's overtoned? This model had a history of the toner supply clutches hanging on causing overfilling of the devs, sometimes to the point that toner would be blown everywhere inside the machine. Only answer is to replace the clutches on the toner hopper units.
      • mkelly1967
        • Dec 2012
        • 25
        It is not over-toned. The black is coming out nice and bold. I think you might be right about the clutches though. When I pull out the transfer unit there is a BIG pile of black toner all along where the imaging unit sits. The cyan has a similar problem but its not a lot of toner. Thanks for the reply!!!
        • JustManuals
          • Jan 2006
          • 9838
          This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
          Paul@justmanuals.com
