We received in some like new low mileage Ricoh Aficio MP 2550N's at work - the USB and Ethernet ports seem to be disabled somehow. I have gone through the manual and cant find anything.
If you plug into rj45 jack there are no lights and if you plug into usb 'b' connection there is no response.
Trying to determine of we should part them out or have someone look at them, is this as simple as having a Ricoh guy come in and enable the port? What should we expect to pay/cost? Or is it bad I/o boards? The units function fine as straight copiers.
thanks
thanks
