Ricoh Aficio MP 2550N -USB and Ethernet Not Functioning or Disabled
  • tekguy
    We received in some like new low mileage Ricoh Aficio MP 2550N's at work - the USB and Ethernet ports seem to be disabled somehow. I have gone through the manual and cant find anything.
    If you plug into rj45 jack there are no lights and if you plug into usb 'b' connection there is no response.
    Trying to determine of we should part them out or have someone look at them, is this as simple as having a Ricoh guy come in and enable the port? What should we expect to pay/cost? Or is it bad I/o boards? The units function fine as straight copiers.
    thanks
  • CRISTIAN MULLER
    • Feb 2013
    • 145
    Re: Ricoh Aficio MP 2550N -USB and Ethernet Not Functioning or Disabled
    Trying to determine of we should part them out or have someone look at them, is this as simple as having a Ricoh guy come in and turn the ports on? What should we expect to pay/cost? Or is it bad I/o boards? The units function fine as straight copiers.
    thanks
    try to perform a factory default clear, dont remember what do but was in service mode at 5 copier option, remember to print all backup data before make this.
    • Elmo
      • Feb 2010
      • 541
      If i remember correctly this model come with a usb and network as standard
      you can enable the usb and network port in service mode
      but unless you have the print scan option installed they will not print
      they require print scan buttons on the left of the display,extra memory a hdd and a print/scan sd card installed
      I Used To Live To Fix Things Now i Fix Things To Live
      • sandmanmac
        • 3981
        A memory clear is dangerous advice that will solve nothing except creating a shitload of headaches - especially after the machine is setup
        Here's what you want to enable the ports:
        COPY SP:
        SP5985-1 (NIC)
        SP5985-2 (USB)
        1=enabled
        0= disabled
        • TonerMunkeh
          Professional Moron
          • 3865
          Scan a config page and post it will ya, we're scratching on the dark without seeing some more information. Personally, I'm going for the wireless authentication being switched on.
          Hit it.
          • Eric1968
            • 2458
            And another one who thinks performing a memory clear solves everything.....
            • mikadonovan
              • May 2008
              • 2931
              Don't do this....
              Check this.....
              COPY SP:
              SP5985-1 (NIC)
              SP5985-2 (USB)
              1=enabled
              0= disabled
              and check this. It's under SP5xxx > 802.11 authentication, I think.
              NEVER ASSUME ANYTHING
              • khaled_abosere3@yahoo.com
                Head technical support
                • Mar 2012
                • 171
                who you mean Eric?
                • Debs1964
                  • Oct 2010
                  • 1693
                  I'm guessing Elmo is correct, I think it's an MP2550B (not heard of an MP2550N), and the printer/scanner kit is an option for this model
                  There are 10 types of people in this world, those who understand binary maths and those who don't
                    • 37533
                    Look at the product code on the serial number label.
                    If it is a D017, it the basic model 2550B. The basic model has no print, scan, or fax. The usb and network jacks are there but no firmware to support them.
                    If it is a D018, then it is either model 2550SP or 2550SPF. The SPF has the fax option preinstalled. Both model support print and scan.
                    • JustManuals
                      • Jan 2006
                      • 9838
                      This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
                      Paul@justmanuals.com
                      • Elmo
                        • Feb 2010
                        • 541
                        When you press the user tools button is there a box in the display that says printer features
                        if not you prob dont have print option installed
                        • Eric1968
                          • 2458
                          Originally posted by khaled_abosere3@yahoo.com
                          who you mean Eric?
                          What I mean is that doing memory clear don't solve anything. It only makes things worse. I'm not going into all details, but it should only be performed when replacing NVRAM's. It never resolves SC's, paper jams, etc...
                          • tekguy
                            this is it, D017 -guess thats why it only has like 19K page through it after being at a large insurance corp, nobody could print to it (they sent it here by mistake and didnt want it back either)
                            is there an upgrade module for this? then again, just sell it off
                            thanks guys!
                            oh yeah, its a 2550B -must have been seeing cross eyed the day i posted this
                              • 37533
                              thanks guys!
                              It can be upgraded using the Printer Scanner Unit Type 3350 which includes HDD, SD Card, Memory. EDP code 416439. This will give you printing and B/W scanning. The 2550B cannot be upgraded to color scanning.
