Ricoh Aficio MP 2550N -USB and Ethernet Not Functioning or Disabled
  • tekguy
    Re: Ricoh Aficio MP 2550N -USB and Ethernet Not Functioning or Disabled
    It can be upgraded using the Printer Scanner Unit Type 3350 which includes HDD, SD Card, Memory. EDP code 416439. This will give you printing and B/W scanning. The 2550B cannot be upgraded to color scanning.
    i cant find anything on that edp code,
    i can find Type 3350 414114
    would 414114 only enable printing? or is it same as 416439?
    • sandmanmac
      • 3981
      I think there was a typo in the EDP code you were given. I'm showing: 414401
      There's also a short discussion about it the Gestetner version of the machine (which is EXACTLY THE SAME) here: http://www.copytechnet.com/forums/ri...p2550b-ad.html
      • tekguy
        thanks for the info, i cant find 414401 for sale anywhere
        • sandmanmac
          • 3981
          #19
          Contact these guys:
          414401 Print Scan Kit Type 3350
