MPC4502 SC792 error with SR3090 finisher
  • jmandassociates
    • Sep 2008
    • 186
    Just installed a SR3090 finisher and BU3060 bridge unit on an MPC4502 and keep getting an SC792 error code. I took the back cover off the finisher and reseated the connections on the main board of the finisher. Not sure what else to try. Thanks.
  • Eric1968
    • 2456
    Re: MPC4502 SC792 error with SR3090 finisher
    The machine sees the Bridge Unit, but it doesn't see the finisher. Could be a faulty harness from the finisher to the machine.
    • Jomama46
      • 2900
      Or the finisher was plugged in before the copier was turned off, in which case, power cycling the copier may solve it. Or replace the finisher main board.
      sigpic
      A+; Network +; PDI+
