Staple in stack sorted
  • joshuadenmark
    • Aug 2025
    [Misc] Staple in stack sorted
    Hi
    Does anyone know how to put a corner staple in a stack-sorted print-copy on Ricoh machines (all new models, mpcxxxx etc.)?
    Hope this question isn't to stupid.
    Nice day to you all.
  • mikadonovan
    • May 2008
    • 2931
    Re: Staple in stack sorted
    Well, first you have to have a finisher capable of stapling. Then you select the corner staple from the display. If you cant see it on the screen, it will be under the "finishing" tab at the bottom.
    NEVER ASSUME ANYTHING
    • joshuadenmark
      I ask because when I select stack sorting i can't select stapling, when doing this the stack sorting goes off...
      • Jomama46
        • 2900
        Also it depends on Which finisher you have, some just have one position others have multi position/staples. But all options will be displayed on the op panel or driver in properties>Setup> page.
        sigpic
        A+; Network +; PDI+
        • joshuadenmark
          Thanks for you answers :-)
          I will try to explain clearer.
          When I select Stack Sort and then select corner staple, the selected Stack Sort gets unselected...
          Like you can't use these two settings at the same time?
          Kind regards
          Peter
            • 37532
            Originally posted by joshuadenmark
            Hi
            Stapling includes sorting.
            • joshuadenmark
              apparently not stack sorting...
                • 37532
                There is sorting and there is stacking. Sorting is putting everything together as sets of all apges. Stacking is printing all copies of 1, then all copies of page 2, etc. Which are you trying to do?
                • joshuadenmark
                  Stacking.
                  • Jomama46
                    • 2900
                    I think you will have to manually staple the stacks
                    sigpic
                    A+; Network +; PDI+
                    • mikadonovan
                      • May 2008
                      • 2931
                      The user manuals can be downloaded from Ricoh-usa. They explain the procedures and limitations.
                      • Debs1964
                        • Oct 2010
                        • 1693
                        Why would anyone have the need to staple a stack of documents that are all the same, I'm confused
                        There are 10 types of people in this world, those who understand binary maths and those who don't
                        • Eric1968
                          • 2458
                          A few weeks ago I had the same problem. Client had a two page Word-document. He wanted page 1 printed twice and stapled, and the same for page 2. The only way to staple is to select the sort option. I called the ricoh guys and they also say that if you want to staple, the sort option will automatically be enabled. Stacking and stapling is not possible.
                          • joshuadenmark
                            I have several clients asking for this function.
                            Thanks for your replies all.
                            • Eric1968
                              • 2458
                              We have a customer that wants that. They want to stack and staple because it's convenient for the truck driver... One copy is for the driver and one copy is for the client where he delivers the goods.
