Blurred or smudged copies
  • ccarvalho@copyvis.pt
    • Oct 2012
    • 10
    [Misc] Blurred or smudged copies
    Hi there
    Just asking if anyone has problems with blurred or smudged copies on a Ricoh MP C7500/6000. I have got 2 machines with the same defect.
    Thank you
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Blurred or smudged copies
    It's usually when the PCU, ITB or PTR lube bars are shot and the cleaning blades need replacing.
    Hit it.
    • kwehner
      • Mar 2009
      • 47
      I have 2 machines that were blurring just a portion in the center of the copy and replacing the drum fixed both of them.
        • Oct 2012
        • 10
        Thank you very much for the info.
        I will replace the k drum for starts, because this only happens with k copies.
        Then we will see how it goes.
          • 37544
          Usually when I get a call for blurry copy on a color MFP it is line position that is off. Clean the ID sensors and then do forced line position c and a.
          • Llama God
            • Mar 2009
            • 1353
            If it's blurring like a 3D image, I'd agree with Slimslob.
            If it's blurring like a smear, as it must be as it's only on black, then I agree with Kwehner.
              • Oct 2012
              • 10
              Yes it is like a smear
              • Llama God
                • Mar 2009
                • 1353
                Oh well, it'll be the drum then. You should do the lube bar, 2 blades, corona and potentially the brush at the same time too. They all do 200k each, apart from the brush which does 400k.
                  • Oct 2012
                  • 10
                  Thank you very much
                  • JustManuals
                    • Jan 2006
                    • 9838
                    This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
                    Paul@justmanuals.com
