Ricoh MP 2550 Toner same mix as ?
  • mrfuser
    • 1626
    Does anyone know if the Ricoh Type 2120 toner is the same recipe mix as any of the other Ricoh toners, such as Type 1130, etc?
    Kelly
  • Eric1968
    • 2458
    Re: Ricoh MP 2550 Toner same mix as ?
    Just use the right toner and don't try to save a few bucks by experimenting with other toners.
    Correct Type for the MP 2550 is Type 2220D.
    • mrfuser
      • 1626
      What a tip! Client ran out, it's Friday and I'm out. Found out there are others that are same mix this I was able pour some into the empty one until more arrives next week. Client works weekends.
      If you answer on this forum please answer the question, very simple.
      thanks all
      • Eric1968
        • 2458
        And if you provide more info then the chance is bigger that you get the right answer.
        • copyaction
          • Oct 2007
          • 991
          • mrfuser
            • 1626
            Very nice tip indeed! Thanks for that!
