MPC 4000 color registration failed
  • Bole
    • Dec 2012
    • 34
    Hi,
    I have problem with color registration on MPC 4000. The problem is in this that is appearing approximately occasionally on 14 days.
    Usually it is not enough to switch ON/OFF, I must to do the SP2-111-3 and SP2-111-1. After that the copier works normaly a few next days.
    I already was cleaning laser unit and the ITB looks ok.
    Did someone had analogous problems???
    thank you for your cooporation
    Bostjan
    • 37365
    Re: MPC 4000 color registration failed
    Originally posted by Bole
    Hi,
    Bostjan
    Have you cleaned the density sensor assembly. It can cause the color registration to go off.
    • Eric1968
      • 2458
      Only magenta is off. Replace the magenta PCU. Maybe the drum is not rotating at the proper speed.
      • joshuadenmark
        1. Clean MUSIC sensors.
        2. Check toner density, too low cause color reg to fail.
        • walterman
          • 196
          I know this is an old thread, however, it helped me out. I cleaned the music sensors and the mfp color reg. was fixed, thank you!
          • joshuadenmark
            Thanks for you feedback, always nice to hear the results.
            • sandmanmac
              • 3979
              Very true. Wouldn't it be nice if the original poster would show the same courtesy and appreciation?
              • Tonerbomb
                AutoMajical Resolutionist
                • Feb 2005
                • 2589
                LIKE !!!
                Mystic Crystal Revelations
                • imihm
                  • Feb 2014
                  • 77
                  Originally posted by Tonerbomb
                  LIKE !!!
                  Hi there...
                  Perform clear all,then run line positioning...
                  Thanks...
                  • Polarbear
                    • Feb 2012
                    • 1070
                    Originally posted by imihm
                    Hi there...
                    Thanks...
                    imihm a word of warning. Never advise someone working on a colour box to do a memory all clear.
                    That NEVER has and NEVER will fix the problem - in fact it wil create MORE problems.
                    Stuff like line position errors have a cause. One needs to find the cause and fix it - Memory all clear is NEVER a fix!
                    Press the GREEN button!!
                    • bob marley
                      • Jan 2012
                      • 1339
                      Hi there...
                      Thanks...
                      wrong
                      Live for yourself and you will live in vain. Live for others, and you will live again
                      • M0scb
                        • Oct 2012
                        • 32
                        As said before, I know this is an old thread. I have had an issue where the speed encoder in the transfer assy had failed. At the time of running the music adjustment, it would compensate. Over time, the belt drive was slipping, causing registration to move. As the encoder is not avaliable as a spare part the only option, for me at least, was to replace the transfer assy. The fault never returned.
                        • alistair
                          Hi
                          Can anyone tell me how to reset the color registration, all three colors are way out on an MP C4000.
                          • lawchatkui
                            • Aug 2017
                            • 79
                            Hi pro, where is the density & music sensor?
                            Sent from my Mi 4i using Tapatalk
                            • Llama God
                              • Mar 2009
                              • 1353
                              Tit
