mpc 4000 copy wraps around pressure roller
  • nodle
    • 142
    Every time my customer tries to print a full page photo the print/copy will wrap around the press roller, and cause a jam code 19.
    I have replaced all drums, ITB, FUSER, Transfer/Sep roller, have done all firmware updates.
    Tried changing fuser temperatures, paper types, lead edge void size, paper direction.... Nothing has had any affect.
    I am slowly going insane on this one.
    Customer claims machine use to do the full page images with no problems.
    Any help with this one will be greatly appreciated.
  • Eric1968
    • 2458
    Re: mpc 4000 copy wraps around pressure roller
    Seems like the paper is causing the trouble. When there's a lot of moisture in the paper the paper gets stuck in the Fusing Unit especially when printing full size color pages.
    • nodle
      • 142
      We have brought our own fresh ream with us.... No change, unfortunately.
      • joshuadenmark
        Are they using original RICOH toner?
        • Polarbear
          • Feb 2012
          • 1070
          What is the leading endge of the page set to? If there is a large amount of black on a full page print, and a small lead edge, it will wrap around fuser rollers, no matter what yu do! This problem goes back to the Af220! Lol!
          Press the GREEN button!!
          • nodle
            • 142
            They are using Ricoh toner.
            I increased the lead edge void with no change what so ever.
            The machine is operating fabulously, other than when they are trying to do these full page color picture for their menu cover.
            They keep telling me this has just started happening. They have had the machine for almost 3 years and have always been able to this particular job.
            • Iowatech
              Not a service manager
              • 3930
              I haven't had the pressure roller wrap problem, but on other problems with full color full page photograph printing I've had some luck changing the settings in user tools to a heavier paper setting. I don't know if that will help, but if time permits you might want to try that.
              I guess you might also want to check the fuser exit guide for the pressure roller to see if it is mounted correctly, sometimes the guide's hinge can pop apart and cause all manner of fuser jam joy. At least if the box your new fuser came in showed any signs of being handled roughly that is something you should do.
              • kannuki2
                • Feb 2012
                • 398
                nodle, did you rebuild the fuser? or was it a new one from the box.
                Check the those one way gear if it's on correct and the entrance guide plate.
                • Canon.Tech
                  • Mar 2009
                  • 335
                  Have you tried heavier paper, say 100GSM or even card as it's only for the customers from page, card would produce a better looking document too!?
                  • SteveF
                    Field Service Manager
                    • Jul 2012
                    • 49
                    Hi
                    Are you useing original toner for this machine or compatible ??
                    • SteveF
                      • Jul 2012
                      • 49
                      I have had the exit unit seize up.. just enough to cause this might want to replace it or change bearings
                      • nodle
                        • 142
                        Thank you everyone for all the good input.
                        I actually was able to get the machine going again.
                        As I had said earlier, the previous tech had not done a pm on this machine. I turned out that the Developer and the devloper units were sooo far out of spec. ( 600k) when the dv is rated at 240k and the units at 480k. It appears that the pages were being so overtoned that it would stick in the fuser unit.
                        All new DV units, along with all the other unit i stuck in the machine, she is prrr'n like a kitten.
                        Thanks again
                        • joshuadenmark
                          Thanks again
                          Super - Thanks for the feedback :-)
                          If possible could You please mark the title [SOLVED]
                          (ok I know I will get "Dumbass Noobie" - rep point for this, but what the heck)
                          • mohan
                            • Oct 2013
                            • 87
                            Check the underside of the fuser stripper-plate for encrusted toner. Be very careful when cleaning it as it easily bends and can make a bad problem worse!
                            • mohan
                              • Oct 2013
                              • 87
                              Check the underside of the fuser stripper plate for encrusted toner.
