aficio551
  • vargue
    • Oct 2011
    • 404
    [Misc] aficio551
    i have 2 machines have same thread when i do scanner adjustment it's failed .any suggestions. it's working but some times sc124 revealed and solved but when i go to sp mode to make scanner adjustment it's failed
  • JustManuals
    • Jan 2006
    • 9838
    Re: aficio551
    This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
    Paul@justmanuals.com
    • Eric1968
      • 2458
      Re: aficio551
      From the Service Manual :
      -Possible cause-
      Scanner motor connector defective
      Scanner motor defective
      MCU defective
      Scanner wire, timing belt, pulley out of position
      PSU defective
      BTW, this machine belongs to the museum....
      • wester
        • Aug 2009
        • 113
        Re: aficio551
        We've had trouble with the scanner pulleys on these. the set screws loosen up and even break.
          • 37533
          Re: aficio551
          Not only does it belong in a museum, if you need parts to repair it you might be out of luck. Termination of parts availability was February 2010.
          Replace the machine. The customer will get much more functionality.
          • Polo-022
            • Sep 2007
            • 486
            Re: aficio551
            Let me guess : PSU
            This is your last choice after all.
            • rhernandez
              • Feb 2013
              • 8
              alignment tool
              I think this one requires the scanner alignment pins. They go in from the top frame to alignment the carriages in the right position. Usually the pulley screws break off the front cable pulley or the back. Then it gets all skewed and maybe the cables pop off. The pins make it slot easier.
