Ricoh 4310N
  • cucuklotz
    • Mar 2007
    • 611
    Ricoh 4310N
    HI,
    I have customer who prints approx. 6000-8k a month. Do you think this machine can handle volume without problems,
    THANKS ANDY
  • Bantams
    • Jun 2012
    • 603
    Re: Ricoh 4310N
    Yes but only for about 2 years.
      • 23009
      Re: Ricoh 4310N
      From what I've read in the brochure it doesn't look so bad. The All-In-One Cartridges are going to be expensive. But if the enduser can install then all by themself, it's not that important. Hopefully the enduser won't try to feed plywood through it. The heaviest media the paper tray will take is 130g/m2, and 162g/m2 for the bypass.
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        Re: Ricoh 4310N
        Ricoh's estimation for the 4310 is AVC at 3000/month. Or 36000/year. I have a Ricoh sp5200 in the field that is running about 44K/month, and there should be a printer version of that engine. Also the 4310 ships with the infamus Starter Cartridge.........
        Mystic Crystal Revelations
          • 37533
          Re: Ricoh 4310N
          Originally posted by cucuklotz
          HI,
          THANKS ANDY
          Lanier's webpage puts the maximum duty cycle at 150,000 prints per month. That is based on a 37 page per minute letter print speed and about a 40% duty cycle, 8 hours, 21 days a month. At your customers expected prints per month, you should be alright. They will exhaust the starter cartridge (6000k capacity) in about one month. After that they should go about 2 months on an AIO cartridge (15,000 K).
