I'm a canon tech but a friend asked me to sort his ricoh fax. i want to increase the number of rings before the fax auto answers ( or enable netswitch/faxability ) he has one line two numbers (fax and phone) i have set it to manual in the mean time and installed an old phone to hear the difference between the rings. i searched the forum and found instructions to get into service mode but they don't seem to work on this model. any help to either turn on selective ring or to get into service mode to increse the number of rings much appreciated.
Ricoh MPC2050 fax rings
Re: Ricoh MPC2050 fax rings
Fax SP Mode > SP 2103-007
That changes the number of rings.- Knowledge not shared, is eventually knowledge that becomes lost... like tears in the rain.
Fully qualified technician for Ricoh - Canon - Sharp - HP - Brother - Knowledge not shared, is eventually knowledge that becomes lost... like tears in the rain.
Copier Technician
1. EnterSP Mode (Press yellow 1, 0, 7 then hold red/clear for about 5 seconds)
2. Select Fax SP Mode
3. Press direct SP then Enter SP 2-103-007 (G3-1 NCU Parameter 06) and set todesired number of rings & press # then exit SP mode.
The Bitch Witch is that it's a Bit Switch!
Halloween Humor from Ricoh!REACH FOR THE STARS!!!
Konica Minolta Planetariums!
https://www.konicaminolta.com/planet...gma/index.htmlComment
shenglang
Hello everyone! ! My friend! Ricoh C3000 color copier results as shown, print effect is not a good question, is there such a failure this copier, optical also cleaned up, and fought copying prospective effect does not work! ! There are no friends friends to know that this is why, thank you!123457.jpg09822.jpgI will not send new stickers! ! Sorry! Thank youComment
