MPC 4502 Intermittently Falls Off The Network
  • Jeffjazzy
    • Aug 2011
    • 18
    Greetings. I recently replaced the controller board on an mpc4502 to correct an SC816 issue. That did resolve the 816 issue but a few hours later the customer started complaining they could no longer print to the copier. Sure enough it lost connection. Thinking I had a defective controller bd I replaced it again and updated the firmware. Same result. Tech support recommended I replace the NVRAM but I'm not to confident thats the solution either. It'll work fine for a while then it drops out again. You turn it off then on and it's fine. I did do a memory clear for the printer and image holding and it seemed to work for a wjile longer and then it was gone again. Anyone have any ideas or seen this? It was fine before I replaced the Vontroller board.
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: MPC 4502 Intermittently Falls Off The Network
    Did you do a memory clear on NCS? Do a print out of the current network settings (System Settings -> Interface Settings -> Print List), clear NCS, then re-input the basic settings to see if it keeps. Also, check that the NVRAM pins haven't been bent; could also be a poor connection.
    • joshuadenmark
      Could be another device with same IP address on the network.
      • joshuadenmark
        Try to set machine to DHCP to obtain IP address from server, and print to host name que instead of ip address.
        • Klydon
          • Mar 2009
          • 243
          I have had a machine or two do this and I talked to one of our network specialists as well.
          Try taking the network port out of "automatic" for speed and lock it on lower speed to see if that helps (it is in user tools). The network tech mentioned sometimes a customer network isn't all that hot and machines can and will drop off due to a variety of reasons, but that locking the port on a certain speed helps a fair amount of time.
          • joshuadenmark
            Could also be an defective port in the network switch.
              • 37488
              I had the same problem with a machine a couple of months ago. After we had replaced everything that had anything to do with the network, the customer moved another known good printer to that location. Same problem with the other printer. They replaced a 5 year old 32 port switch and problem went away.
              • Jeffjazzy
                • Aug 2011
                • 18
                Thanks to all the reply's on this issue. I followed the recommendations of the last person I spoke to at Ricoh's tech support and she had recommended that I do a Memory Clear of just the printer and Image handling. That was last Wednesday or Thursday I believe and I returned today and they said it's been running fine. They will be using it very heavily this Wednesday coming and that will be the test to determine if it's reall okay. We shall see! But again thanks for all the input. If it doesn't hold up at least I have a few more things to try.
                • Copier Whisperer
                  Geezer Tech
                  • 41
                  I recently heard this from our Regional Rep. have the network people disable SNMP. The theory is that Microsoft had an update that is now causing this problem for many different brands of MFPs.
                  • SargeNZ
                    • May 2012
                    • 263
                    I can back up the advice to turn off SNMP reporting on the print queue. There is a problem where some MFD's will report as 'offline' on some MS servers, even though they are fine and direct printing works. Turn off SNMP, server no longer thinks the MFD is offline and hey presto, printing works.
                    • qbert69
                      • Mar 2013
                      • 1152
                      Ditto for the SNMP turnoff...It worked for me just the other day!
                      REACH FOR THE STARS!!!
                      Konica Minolta Planetariums!
                        • 37488
                        It can happen both on servers and work stations. If the MFD receives a SNMP request that it does not recognize, it does not respond. When the computer does not get a response to the request within a specified time, it assumes that the printer is offline.
                        • shenglang
                          Hello everyone! ! My friend! Ricoh C3000 color copier results as shown, print effect is not a good question, is there such a failure this copier, optical also cleaned up, and fought copying prospective effect does not work! ! There are no friends friends to know that this is why, thank you!123457.jpg09822.jpg
