Toner on Metis printouts can by erased
  • swissriddle
    • Feb 2011
    • 8
    [Misc] Toner on Metis printouts can by erased
    Hello World
    The letters and lines can be erased by a normal eraser....
    Any ideas?
    - Rise the fusing temperature wasn't successful
    - Firmware are up to date (2013-10-28)
    - Machines are new. (500-1000 printouts)
  • Zeldaman
    • Mar 2011
    • 946
    Re: Toner on Metis printouts can by erased
    Hi there!
    Which type of Metis, what kinda paper, some more details please.
    Greetings...
    • swissriddle
      • Feb 2011
      • 8
      Originally posted by Zeldaman
      Hi there!
      Greetings...
      it's happend an all METIS. Actually on the MPC3003, 3503, 4503 and 5503.
      For this issue, the type of paper it doesen't matter.. but anyway, it's a high Quality paper from ricoh ltd.
      • Gift
        • Mar 2011
        • 2459
        Interesting but not reproduceable with my demo machines (loaded with color copy paper)
        • swissriddle
          • Feb 2011
          • 8
          I tryed on many machines.. about 20! and it happened on all of These. i just tryed with normal 80gr/m2 with paper, not Color copy
            • 37532
            Does it only happen in spots or can you erase the entire page? If it only in spots, I would suspect something involving the paper. It could be excess moisture from improper storage.
            • Gift
              • Mar 2011
              • 2459
              That's pretty strange - I tried really hard with an eraser but no effect. Can do a test with normal paper tomorrow but I'm shure I would've get calls if one of our picky customers would have recognize this.
              • salvador zambrano
                • Nov 2011
                • 25
                Have you tried replacing hot roller ? (seeing that it new you might not want to replace it.) but I have seen the inner coating in hot roller start to flake off and cause problems like yours. just an idea to check.
                • swissriddle
                  • Feb 2011
                  • 8
                  Hi, did you tried it? I have replaced the fusing unit, but i still have the same Problem..
                  • Elmo
                    • Feb 2010
                    • 541
                    Hi are you using original toners
                    I Used To Live To Fix Things Now i Fix Things To Live
                    • swissriddle
                      • Feb 2011
                      • 8
                      of course, all original parts
                      • Iowatech
                        Not a service manager
                        • 3930
                        This might be stupid, and if so sorry about that, but what is "Metis"? I tried searching for it, but couldn't find anything useful.
                        Just want to make sure I'm not missing something important.
                        • turbojetboy
                          • Aug 2009
                          • 279
                          It is important, so here is what it's all about - The Greek word metis meant a quality that combined wisdom and cunning. This quality was considered to be highly admirable and was regarded by Athenians as one of the notable characteristics of the Athenian character. Metis was the one who gave Zeus a potion to cause Kronos to vomit out Zeus' siblings
                          Got it?
                            • 37532
                            Read all the posts and you shoulds be able to figure it out.
                            • Bantams
                              • Jun 2012
                              • 603
                              Metis is the name given to the machine that replaced the Athena and Apollons C3s
