MP C3300, Win 8, and large pdf docs
  • mikadonovan
    • May 2008
    • 2931
    Hi, All. I have a customer that just upgraded to windows 8 printing to a D025. They are a construction company that prints large PDF files. (19M, 52 pages) The original document was created as 30x42", and is being printed on 11x17. With the original embedded WIN 8 Ricoh class driver it took an hour to print the PDF. With the new driver, it spits out 7 pages immediately and then waits forever. Driver settings (PCL6) are standard resolution and black and white. What can I do to increase printing speed? Their IT gal and I seem to be like oil and water at the moment. My machine has the latest drivers and firmware.
    NEVER ASSUME ANYTHING
  • mikadonovan
    • May 2008
    • 2931
    Re: MP C3300, Win 8, and large pdf docs
    Never mind, it looks like they had a corrupt PDF.
      • 37059
      If by "the original embedded Win 8 Ricoh class driver" you mean the Microsoft driver that come with Win 8, you need to download and install a true Ricoh driver. I have never had much luck with Microsoft drivers. With Ricoh PCL 6 driver, go to Printing Preferrence - Detailed Setup - Print Quality, what ever Vector/Raster is set for, change to the other.
      • qbert69
        • Mar 2013
        • 1152
        Whatever program they are using to generate their "PDF" make damn sure that the "flatten" the layers of that file into one layer in the PDF and then in the print driver choose the "Print on-->11x17" in the print driver options....otherwise you will be waiting a long time for the MFP to flatten those layers AND which can lead to a memory overflow on the MFP causing it to error out!
        Good Luck!
        PS--Always use OEM Drivers!
        (microshaft drivers like to break things!)
        REACH FOR THE STARS!!!
        Konica Minolta Planetariums!
        • shenglang
          Hello everyone! ! My friend! Ricoh C3000 color copier results as shown, print effect is not a good question, is there such a failure this copier, optical also cleaned up, and fought copying prospective effect does not work! ! There are no friends friends to know that this is why, thank you!123457.jpg09822.jpg
          • mikadonovan
            • May 2008
            • 2931
            Originally posted by shenglang
            Hello everyone! ! My friend! Ricoh C3000 color copier results as shown, print effect is not a good question, is there such a failure this copier, optical also cleaned up, and fought copying prospective effect does not work! ! There are no friends friends to know that this is why, thank you![ATTACH=CONFIG]22703[/ATTACH][ATTACH=CONFIG]22704[/ATTACH]
            You might want to start a new thread for this issue, Dude. It's not even the same model machine. PM count on pcu's and developer?
            • ruben
              The New Guy
              • Oct 2012
              • 1203
              Looks like someone has put their hand right across the drum/dev roller surface.
              • digicor
                • 1152
                "the original embedded Win 8 Ricoh class driver" this driver should be destroyed!!!
                waste of time using this driver
                • Eric1968
                  • 2458
                  Look at his previous posts. He has posted this question numerous of times with different thread titles. Spammer maybe?
                  • drwevil
                    • Nov 2013
                    • 53
                    Usertools>Printer Features>System>Memory Usage> Set to Font Priority... This applies to all Ricohs that have it not just this model.
                    it works a treat and it can sometimes solve a whole bunch of weird print issues.....
                    but yes those Microsoft drivers a crap with a capital CRAP!!! Don't ever use them...
