Ricoh afico 2075 SC490
  • Deer John
    • Aug 2013
    • 21
    [Error Code] Ricoh afico 2075 SC490
    Codes out, will not reset. I know that this is an exhaust fan error code, but am unsure where it is located. Does anyone have a rough location or parts number for the exhaust fan or fans related to this code?
    • 37383
    Re: Ricoh afico 2075 SC490
    Book says main cooling fan. Also check the waste toner system for clog coming from the transfer belt unit.
    • bobbykerr
      • Sep 2012
      • 52
      Yeah defffo waste toner system clogged had loads of times
      • katash
        • May 2010
        • 221
        its one of this cooling fans but you have to identify which one, AX650030 OR AX640136
        • shenglang
          Trackback
          • shenglang
            Re: Ricoh afico C3000 Copying Problems
            Hello everyone! ! My friend! Ricoh C3000 color copier results as shown, print effect is not a good question, is there such a failure this copier, optical also cleaned up, and fought copying prospective effect does not work! ! There are no friends friends to know that this is why, thank you!09822.jpg123457.jpg
            • JustManuals
              • Jan 2006
              • 9838
              This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
              Paul@justmanuals.com
              • Ronan
                • Aug 2011
                • 55
                broke the main fan is back. regards
                • fshead
                  • 2366
                  i thought 495 was the waste toner bind/clog etc problem..
                  on these older ricohs the main fan doesnt come up to speed.
                  i think as you face the back its the one to the left.
                  i have blown them out and pulled the label on the outside cover exposing the main bearing..
                  hit it wth wd40,spin the fan and reconnect n see if it spins on power up.
                  when you get it running i put some light grease and cover hole/bearing wth tape..
                  good luck
                  • mohan
                    • Oct 2013
                    • 86
                    I have come across this in the past. Eventually cleared the problem by completely purging the toner supply system. See service manual section for procedure to follow when having to put the machine into storage or transporting it. (The machine had been sitting un-used for awhile).
