Ricoh MP 5500 Finisher problem
  • gidon
    • Sep 2008
    • 0
    Hello, we have copule of Ricoh MP5500, it seems the paper come out of finisher shift tray is slow, so paper can not load in tray properly, any advise ? apprericate your response.
  • Iowatech
    Not a service manager
    • 3930
    Re: Ricoh MP 5500 Finisher problem
    More information, please?
    In the mean time, if that is the tray I'm thinking of, you might check the foam rollers on that tray, they could be worn out. Or the paper might not be flat enough to stack properly.
    Sorry if that doesn't work.
    • Eric1968
      • 2458
      Another thing to look at are the bushings of the exit section of the finisher. Over time they're collecting dirt and this leads to jams at the exit section.
      • Bantams
        • Jun 2012
        • 603
        The sponge rollers above the shift tray need replacing.
        • Codex
          • May 2008
          • 704
          Had the same problem on a couple of finisher......check the exit roller bushings, and the sponge rollers, but in my case the problem was caused by dirt inside the exit bushings
          Memento Audere Semper
