ricoh mpc4500 missing adress book function
  • digicor
    • Jul 2008
    • 1159
    It worked when i got there!! I was turning on the usb function, for the customer to print usb cuz he aint got no internet.... and i re booted the machine and the e mail , folder quick touch is gone. it says its unavailable???
    please someone tell me what happened to it? or is the usb on causing this to diss-appear? i switched it back on and off, no quick address book still.
    any ideas?
  • digicor
    • Jul 2008
    • 1159
    Re: ricoh mpc4500 missing adress book function
    well still no luck, the quick dial boxes are still unavailable... anybody?
    • sandmanmac
      • 3981
      Sorry, I'm still a bit unclear on exactly what you're saying.
      Is it that the "email" / "folder" buttons that are typically displayed, are missing completely? as well as some 'pre-programmed" destinations?
      How about the "frequent" buttons.
      Does it have a fax option, and is the screen normal?
      The typical address book issues I've had have been related to HDD issues. Did you try reformatting?
      • digicor
        • Jul 2008
        • 1159
        Is it that the "email" / "folder" buttons that are typically displayed, are missing completely? yes,
        the are gone, the only way to send something is manual destination,
        I will try to re form the hd and see if that brings it back,
        I have never seen this in all my days as a tech.
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          Before you format go into the address book and see if there are entries, after formatting there will be NO entries!!!!!!!!!!!! Also after formatting do 5846-50 to initialize the address book....
          Mystic Crystal Revelations
          • Dougtech
            • Apr 2011
            • 113
            I would use the web interface to backup the address book before format, then you can just re-up it.
            • Bantams
              • Jun 2012
              • 603
              When turning on the USB did you turn the Ethernet off?
              If so that's why :/
              • digicor
                • Jul 2008
                • 1159
                no i did not, but i will check to see if if got turned off somehow.
                thanks for the heads up
