please help !! ricoh mpc 2050
  • dreaqgol
    • Aug 2025
    [Misc] please help !! ricoh mpc 2050
    i have a ricoh mpc 2050 and suddnly prints like this ..( see pdf attach)
  • JustManuals
    • Jan 2006
    • 9838
    Re: please help !! ricoh mpc 2050
    This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
    paul@justmanuals.com
    • ricmartinho
      • 142
      My guess is some problem with the Black IU. It's a pretty simple machine.
      • dreaqgol
        how can i repair the black iu ?
        • sandmanmac
          • 3981
          Simple. Call a tech
          • dreaqgol
            Originally posted by sandmanmac
            Simple. Call a tech
            the nearest tech is in hungary at least 1000 km
            • Eric1968
              • 2458
              Bd Burebista Nr 2, bl D14 sector 3, Bucuresti, ROMANIA
              Telefon: 021.323.35.55, 0727.300.617
              Fax: 021.322.09.67
              Email: call-center [at] roelgroup.com
              Just a simple Google Search...
              • Eric1968
                • 2458
                Forgot to mention the company name : Roel Group
                • Canon.Tech
                  • Mar 2009
                  • 335
                  I agree, looks like you have a drum & developer fault.
                  The black lines are caused by the drum & the other black marks are caused by the developer unit.
                  • Codex
                    • May 2008
                    • 704
                    this normally happens to machines with more than 100.000 black copies, its a developer leak, you have to replace the Black Dev unit, check also the drum unit for a dirty charge roller...pull out the black pcu unit and look inside the machine, you should see the developer inside, and over the laser shutter, after replacement clean very well the inside of the machine, specially the laser shutter and the protection glass.....good luck!
                    Memento Audere Semper
