Customer never set up the scanner function and asked if I could set up a folder for scanning.When I tried to enter admin mode to access the address book the user/password where not any of the standard combinations.There doesn't appear to be a supervisor mode so I'm wondering is there an SP to reset the user/password back to default?
Ricoh 2022 admin password can't get into address book
Re: Ricoh 2022 admin password can't get into address book
I have always used the WIM, I didn't know you could do it from User ToolsThis copier was a lease return so the previous owner reset the password, user tools is not locked but are you able to enter the user/password for folder authentication from usertools also?Thanks.Comment
I have always used the WIM, I didn't know you could do it from User Tools.This copier was a lease return so the previous owner reset the password, user tools is not locked but are you able to enter the user/password for folder authentication from usertools also?Thanks.Comment
The default credentials for the WIM on that older unit are:
username: administrator
pasword: passwordComment
This uses a Key Operator code, not a Login/password combo. You can reset it in service mode, not sure of the exact SP but you will find it in 5xxx.Comment
For some reason I can't edit my above post, but the correct SP is 7-810 to reset (Access Code Clear).Comment
Also.
My android app has been down all day tooComment
Got this from the Knowledge Base......What to do if the administrator password is forgotten Print Notify MePublished 08/15/2007 10:27 PM | Updated 06/30/2008 10:34 PM Answer ID 71499 | FAQ ID 71324 | Rank A2What to do if the administrator password is forgotten.Administrators do not need to enter a username. They only need to remember their password. If this password is forgotten, please try the following:1) The admin password is the same for both WebImageMoniter and telnet. Ask whether the customer remembers either of the two.2) Try the factory default "password".3) If both 1) and 2) do not work, a service engineer has to reset the password for the customer. Follow these steps:3-1) (IMPORTANT) Print a configuration sheet at the beginning. You will need the configuration sheet to restore the network settings. 3-2) Enter SP mode.3-3) Enter SP 5-801-011 (Memory Clear > NCS).3-4) Press [Execute].3-5) You will be asked for confirmation. (IMPORTANT) This will reset all of the network and interface settings. Make sure you have printed the configuration sheet. Press [Execute] once again.3-6) Turn off the device, then turn it back on.3-7) Restore all the network settings to the values of the configuration sheet.3-8) The above steps should have reset the password to the factory default, "password".3-9) Finally, the customer should log in to the device and change the password to their own. This can be done using Web Image Monitor or telnet ("passwd" command).Comment
Well, when I pasted in the above info the formatting was a lot neater, after 'submit' it went south. Something going on currently with this site apparently. Hope it makes sense though.Comment
