mp 4000 light copy
  • jshah
    • Aug 2013
    • 56
    mp 4000 light copy
    mp 4000 light copy problem
    replaced drum developer cleaning blade transfer belt etc. problem not solved. any ideas?
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: mp 4000 light copy
    Are the prints good? If so, give the optics a good clean. If not, check the laser glass and then see if a forced toner supply affects it at all.
    • daveyball
      • May 2009
      • 314
      There are mylar sheets in the toner supply case where the bottle goes in that get crushed, this stops the toner bottle turning properly, and therefore toner supply.
      • jshah
        • Aug 2013
        • 56
        prints are also light. even with new developer first cpoies are light. also cleaned lase unit glass but to no success.
        • daveyball
          • May 2009
          • 314
          There was a modified dev unit for this model, we have replaced a couple for this fault
          • Debs1964
            • Oct 2010
            • 1693
            There are 2 connectors on the transfer, if these are connected the wrong way round then you will get faint copies
            There are 10 types of people in this world, those who understand binary maths and those who don't
            • Mad_Coachman
              • 99
              Is the mag roller in the dev unit black? If it is then you will have to clean it with a scouring pad until it is shiny. This is a common problem with this series.
              • Elmo
                • Feb 2010
                • 541
                Check and clean the ID sensor sits just above the drum unit
                I Used To Live To Fix Things Now i Fix Things To Live
                • Oze
                  Ricoh Fanboy
                  • Jul 2008
                  • 1663
                  OR in future don't even bother rebuilding the pcdu....just modify and fit the printer unit from an SP8200.....you'll need the SP8200 A kit.....the SP8200 B kit contains a fuser and transfer assy.....both of which fit the copier with NO modification required.
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    And did you just clean or replace the charge roller?
                    • Oze
                      Ricoh Fanboy
                      • Jul 2008
                      • 1663
                      A coated mag roller tends to give a dark background on prints/copies rather than light.
                      • Debs1964
                        • Oct 2010
                        • 1693
                        As does a dirty charge roller
                        • collme
                          Ricoh tech
                          • 221
                          have had to remove the laser and clean on these as toner manages to get around the shield and contaminate the actual laser unit. not hard to remove on these machines.
                          • Debs1964
                            • Oct 2010
                            • 1693
                            Where have you been, I thought you'd deserted us
                            • collme
                              Ricoh tech
                              • 221
                              just had a break from here lol
