MP4000 Transfer Belt
  • nodle
    • 142
    I have been trying to figure this one out for quite awhile now, and it may even be a goofy question.
    A few of my Mp4000's tranfer belt rides to the rear frame causing the belt to make a rubbing noise and to cut a grove into the tansfer belt arm. I have tried to make adjustments to the belt arms and rollers to get the belt to stay centered, but after a time they seem to ride to the rear frame again.
    I have even tried a couple brand new transfer belt units with the same result.
    Has anyone seen this before, and if so have you figured out what is causing it?
  • DH1980
    • Mar 2009
    • 52
    Re: MP4000 Transfer Belt
    We are seeing it also. Can make a lot of noise. Have not found a fix yet.
    • JustManuals
      • Jan 2006
      • 9838
      paul@justmanuals.com
      • J.arnault
        Hello have you find the solution ??? i have the same problem on a MP5001 .
        Help please
        • rthonpm
          • Aug 2007
          • 2860
          Do you coat the cleaning blade with toner? At least on the older series that seemed to help keep noise down, and to keep the belts from riding...
            • 37653
            I have not seen the problem on 40 and 50 page machines, but I have seen it on 60-90 page machines when one of the arms cracks or one of the ball bearings fails. If the belt fits tighter at one end that the other it will walk toward the tighter end. It could be the belt itself, uneven pressure from the cleaning blade, or the rollers not being parallel as from bad bearings or cracked arm.
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              Have you tried fitting a printer kit ITB assy?
              We tend to do this as it's a cheap/time saving solution.
                • 37653
                This is about the paper transfer belt used on 40 and 50 page black/white machines, not the ITB used in color MFPs. Used the same belt since the Aficio 350 and 450.
                • Iowatech
                  Not a service manager
                  • 3930
                  I've seen that a couple of times on the older 35/45 CPM machines, and I mostly agree with Slimslob. Check what he told you to.
                  But I'm curious, what kind of environment is the machine exhibiting that problem in? While normally when I saw that problem back in the day it would indicate that the transfer belt and cleaning blade needed to be changed, it sounds like you have already tried that. But I have seen that a couple of times in places where the users were strong people that worked very hard with large machines, and would occasionally treat their MFDs and printers the same way. In the somewhat unlikely circumstance the problem machine is in that type of environment, you might want to check where the transfer unit attaches to the right hand door.
                  • Oze
                    Ricoh Fanboy
                    • Jul 2008
                    • 1663
                    They need an emoticon for an embarrassed face....totally missed the fact that it was for the B/W
                    • Gift
                      • Mar 2011
                      • 2459
                      THere's a mod bulleting for the transfer beld holder frame thingy IIRC but it doesn't really fix this well known issue.
                      • J.arnault
                        in fact the problem is that the belt moves to the bottom of the copier,
                        I try to change the complete transfer unit but it's the same
                        • Gift
                          • Mar 2011
                          • 2459
                          it's a habit of this series - doesn't really affect the function or lead to noise issues in most cases. A mate of mine did some sort of mod with teflon tape in order to supress a noise issue and we also replaced the frame part with the modified one to resolve a noise issue - still the belt is always running more or less tendy towards the rear side of the engine.
