Savin 9050 Copier
  • RonMac
    • Oct 2008
    • 57
    Savin 9050 Copier
    How do I add, delete and change the user code on a Savin 9050 that I am working on in the shop. It is not connected to a computer and the previous owner does not have the user code. Can I use a service code to over ride or bypass the user code? Thanks for any help. Ron
  • ruben
    The New Guy
    • Oct 2012
    • 1204
    Re: Savin 9050 Copier
    You can also bypass the codes by either turning them off in User Tools, or go to System/Copy SP then click on the Copy Window button.
    • RonMac
      • Oct 2008
      • 57
      Originally posted by ruben
      http://support.ricoh.com/bb_v1oi/pub...l/int/0145.htm
      Thank you Ruben....I will try that tomorrow. Ron
      • RonMac
        • Oct 2008
        • 57
        Thought you might like to know I was able to clear all the codes and found the NV Ram Chip had a bent leg. It's up and running. Thank you again and enjoy the holidays. Ron
