Disable colour scaning in ricoh mp 9002
  • manoj.k.nair
    • Sep 2012
    • 50
    [CQ] Disable colour scaning in ricoh mp 9002
    Dear All.
    Is it possible to block colour scaning in MP 9002 B/W COPIER ?.
    Is there any tips?.
    pls update.
    manoj
    M N AIR
  • sandmanmac
    • 3981
    Re: Disable colour scaning in ricoh mp 9002
    I don't think so, but I'm dying to know what your reason is?
    • manoj.k.nair
      • Sep 2012
      • 50
      Reason is that , copying from university certificate and other resticted original is not possible.
      If you copy from those originals copy will be full black or half black. we are facing from this problem in photocopying centers. COPY DATA SECURITY NOT THE REMADY FOR THIS PROBLEM.
      M N AIR
      • Eric1968
        • 2458
        This is one of the security measures of the machine. You can't copy it, but scanning in color (and then printing) is possible.
        • kannuki2
          • Feb 2012
          • 398
          Originally posted by manoj.k.nair
          Dear All.
          Is there any tips?.
          pls update.
          manoj
          here's a suggestion... what if you put a user code lock on scanning? allow all users to use blk and white scanning only. I don't know if that is possible. check the Operation Manual.
          • Debs1964
            • Oct 2010
            • 1693
            I don't think that's possible, I think you can only lock down colour copying and printing (on colour devices), or lock all scanning, I've never seen anywhere to choose scanning features that can be locked out.
            I'm still not sure I understand why anyone thinks blocking colour scanning is going to resolve the original problem which is a copying problem
            There are 10 types of people in this world, those who understand binary maths and those who don't
            • ss12
              • Jul 2008
              • 289
              Why not set the scanning to default to b/w
              • rsyarcia
                Hair Straightener Tech
                • 711
                agree with SS12 , try to make the default as B/W scanning, maybe the user can't change the settings unless he is an admin.
                Nobody is perfect..
                • Eric1968
                  • 2458
                  You can limit scanning in general, but you can't limit color scanning and use B/W scanning "for free".
                  • manoj.k.nair
                    • Sep 2012
                    • 50
                    Dear.
                    IAM FACEING THE PROBLEM WITH A COPYING JOBER.PHOTO COPYING JOB]
                    HE IS GETING LOTS FOR ORIGINAL [ UNIVERSITY CERTIFICATE, COPY RESTRICTED ORIGINAL.] FOR COPYING .
                    HE IS UNABLE TO TAKE COPIES ,BECAUSE ALL THE PRINT OUT WILL BE HALF BLAK OR FULLY BLACK. HE IS USING OUR AF2060 .IT DON'T HAVE THIS PROBLEM BECAUSE IT HAS ONLY B/W SCANING.SO HE IS REFUSING THE 2 NO: MP9002SP,WHICH I RECENTLY INSTALLED.
                    PLS REPLY.
                    THANKS.
                    M N AIR
                      • 37513
                      If the concern is that they want bypass Copy Data Security of color originals by scanning in B/W and then printing, the solution is to disable color printing. This is done through user code restrictions. You can also edit the print driver to only allow B/W printing.
                      I feel confident that in the near future Ricoh will incorporate a Copy Data Security type feature in scanning, i.e. if you will not be able to scan a secure original.
                      • teebee1234
                        • Jul 2008
                        • 1670
                        Setting Menu Protect to Level 2 in Scanner User Tools might work. Worth a try.
                        Menu Protect
                        In addition to the System Settings, Menu Protect limits user permission to access the initial settings menu
                        for each function. This function is also effective when management is not based on user authentication.
                        To change the menu protect setting, first enable administrator authentication. For details on how to set
                        administrator authentication, see p.15 "Configuring Administrator Authentication". For a list of settings
                        that users can specify according to the menu protect level, see p.305 "List of Operation Privileges for
                        Settings".
                        Scanner Function
                        1. The machine administrator logs in from the control panel.
                        2. Press [Scanner Features].
                        3. Press [Initial Settings].
                        4. Press [Menu Protect].
                        5. Select the menu protect level, and then press [OK].
                        6. Log out.
                        • Llama God
                          • Mar 2009
                          • 1353
                          Dear.
                          PLS REPLY.
                          THANKS.
                          Yes, shouting will work, it always does.
                          In Scanner SP there may be an option to turn on RTFM mode. I can't recall exactly where it is, without resorting to reading the f'ing manual.
                          • tcs04
                            FORMER Techie
                            • 1183
                            it's in the I . D . 10 .T section!
                              • 37513
                              Now is that binary or decimal?
