fuctional prop with mpc6501
  • digicor
    • Jul 2008
    • 1152
    after a while or so when the machine has a print job sent to it,
    it displays functional problem
    Im going to re format the hdd but if this isnt the prob, what else besides the main controll board could fix this issue
    im not sure what the print perpetrators are set at just yet, im going to the client today.
    thanks
  • Eric1968
    • 2458
    Re: fuctional prop with mpc6501
    Well, the MP C6501 is one big functional problem, just kidding.
    Check your SC-history. Every functional problem generates an sc-code and some of them are not visible, but they are logged.
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Make sure the firmware is up to date, there are plenty of SC899 etc print problems with this model. Also, clear your Printer Application memory, then re-send the job. If it still happens try using a different program to print from.
      • JustManuals
        • Jan 2006
        • 9838
        Paul@justmanuals.com
        • digicor
          • Jul 2008
          • 1152
          OK well I did 5801-11
          re set the I/O buffer to 256
          and the it guy had the mpc6000 ps driver, i loaded the e7200 pcl5c driver
          Nic set to auto
          ran 3 sets of 75.. NO Prob
          Thanks for the Ideas
