Priport Ricohjp5000
  • cliffhangers
    • Feb 2010
    • 243
    Priport Ricohjp5000
    I am haven problems with Ricohjp5000 it's not pumping ink to the drum,it was working when the ink get finish and i change the ink fit in new one then it start to print very light and it is the same ink i am always using.i need help to solve this problem.THANKS IN ADVANCE.
  • JustManuals
    • Jan 2006
    • 9838
    Re: Priport Ricohjp5000
    Paul@justmanuals.com
    • rsyarcia
      Hair Straightener Tech
      • 711
      check the ink detector inside the drum
      Nobody is perfect..
      • greyfox
        • May 2010
        • 20
        check the pump unit and sensors
