I have custumers that have meany problems when they used the bridge unit (used for function to the sorter/finischer).
When the Paper (witch duplex mode) has een little curle on the leading edge, the leading egde of the paper gives
jams in the beginning of the bridge unit (because there is (I think) en to small opening in the entrance of the bridge unit). The MFP gives than on location 62 many jams.
The paper is not the probleem (40% HD), I have Tray heaters installed in the machine.
The Orval is model MP2852-series
What can I more do om this problem to solved, are there engineers with the same problems by custumers that used this MFP Bridge Unit/Finisher/ and copie or printing with duplex mode.
