ricoh cl4000 dn Replace Inttrans Unit message will not clear
  • walterman
    • 196
    I just replaced the transfer belt on a Ricoh CL4000DN. I made sure the printer was unplugged, power and interface cords, I installed the belt, plugged the printer back in. The printer still has the message? Pardon my ignorance, however, I was expecting the printer to "reset" the count. How do I reset the count manually? Thank you.
  • sandmanmac
    • 3983
    Re: ricoh cl4000 dn Replace Inttrans Unit message will not clear
    I believe it generally does reset automatically, but if not, then you can reset with SP Mode 7804-009
    • Counsel
      • Aug 2011
      • 529
      Pretty sure on that one you hold the up and down buttons for like 5 seconds, then release and hit OK/Enter button should give you a Service ? Engine/ End menu, choose engine for SP mode
        • 37553
        That is method 2 for use when the machine is already on. If the machine is off press and hold the "On Line" key and the "Escape" key together while turning on the power.
        • walterman
          • 196
          Thank you for all the information. I was able to clear the message; however, (lol) I found pressing the on line and escape buttons, simultaneously, damn near impossible, my fingers are still cramped from stretching, moreover, the issue is resolved.
