Doctor blade gap
  • rnrplayhrd
    • May 2025
    [Misc] Doctor blade gap
    Does anyone know what the gap for the doctor blade on a Ricoh MP7001 developer unit should be?
    Thanks,
  • Eric1968
    • 2458
    Re: Doctor blade gap
    Do you want to adjust it for some reason?
    • Bantams
      • Jun 2012
      • 603
      its about this big ..
        • 37062
        I believe that it is set at the factory. If you have taken it loose for any reason, you will probably have to replace the development unit.
        • nmfaxman
          • 1702
          Measure a known good one.
          Wipe the developer to one side and try different size feeler gauge.
          Use a metric gauge, the copiers are designed in Japan.
          I have found on all Ricoh products is that the DV brush is too high.
          I have found that some fresh out of the factory were uneven, as much as .2mm.
          I set all 35/45 machines to a TIGHT .35, .30 slips without turning the mag roller easy and .4 won't fit.
          • zed255
            How'd ya manage that?
            • 1024
            From what I have measured in the past these units have a gap set at the factory to 0.45-0.50mm. There is no official specification, they are factory set and supposedly not to be adjusted in the field.
            Nuts to that, I have been setting this family of products to a snug 0.35mm and setting the toner supply rate from the stock value of 850 to 650 to help keep things running cleaner. Where some units couldn't get to 100k I'm now seeing cleaner machines out past 200k and even reaching life on the less problematic ones. Cleaning the mag roller is critical - use a small brass brush to get the grooves really clean.
            • HDSB
              Field Tech
              • Feb 2013
              • 64
              I once removed this while doing my apprenticeship in our workshop. The look on my mentors face after he saw what i done..
              • rnrplayhrd
                Great answer! Thanks, this really helps. I had a Dr. blade cleaner, one of those plastic strips, break off behind the blade and couldn't get it out. After replacing the blade i used that same strip as a guide and it worked fairly well. The copy's are ok with just a little background. Next PM I'll try the settings you recommended to try to clean it up.
                Thanks again!
                • KapeKopyTek
                  • Nov 2013
                  • 285
                  If you like your doctor (blade), you can keep your doctor (blade). >smirk<
                  • Herostrat
                    • Oct 2012
                    • 220
                    I had one 2060 on field with uneeven doctor blade,I have no idea how it happened,it was first and only time I had that problem so far.
                    Machine wuld to about 3 or 4 prints and then SC441 pop's out...developement motor lock.
                    I noticed a pile of developer on dev. housing beneath mag. roller,made me think it piled up on that place and then bursts out true the gap,locking developing assembly.
                    Since I didn't have much options on field I placed 2 papers in doctor blade gap to make it even and tighened the screws,that gap wasn't good enough so I placed 3 papers in,tightened the screws and it worked like a charm.
                    So in summary I think gap is wide about 3 papers.
