MP C305SPF MESSAGE : Cartridges are not set correctly (Black only)
  • copier tech
    • 8238
    #16
    Re: MP C305SPF MESSAGE : Cartridges are not set correctly (Black only)
    Facing the same issue but with an MPC307, it appears the design is the same as the 305!?
      • 37655
      #17
      Hey grave robber, start a new thread.
      • copier tech
        • 8238
        #18
        Na dig up an old one!
        • Dan G
          • Nov 2014
          • 56
          #19
          this is a result of toner mess in side. requires a massive cleaning to prevent toner bottle shutter stoppers from sticking and preventing bottles from fully inserting and not contacting RFID
          • copier tech
            • 8238
            #20
            Great PDF simple to the point.
            I blasted the BRB pcb with air & fitted a new black toner bottle started working ok.
            If issue returns will fit new brb & hopper.
