MPC2550 color backgrounding
  • digicor
    • Jul 2008
    • 1159
    In color copy mode im getting purple backgrounding
    i can print out color sheets look great, if i copy them i get this?
  • KapeKopyTek
    • Nov 2013
    • 284
    Re: MPC2550 color backgrounding
    Through the doc feeder or off the glass? Or do you get the same thing both ways?
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Do a memory clear on the copier memory, and clean the white reference plate just in case.
      If it is still there you may need to do an engine clear, as long as you have the factory defaults sheet.
      • sandmanmac
        • 3981
        I`m betting that a full memory clear is probably what caused the issue in the first place. As Ruben said, hopefully you have the factory data sheet to re-enter the settings
        • digicor
          • Jul 2008
          • 1159
          Hmmm, i will see if the fac default sheet is with the machine,
          thanks, its a billable non service client so im not sure who or what has been done to it.
          Isnt a default setting's listed in the serv man?
          • ruben
            The New Guy
            • Oct 2012
            • 1203
            No two machines are built the same, settings will differ between them. You may be lucky and find that one machines settings may work, but I would rather aim to input the defaults.
            The manual will only give you a rough sense of what the settings should be.
            • sandmanmac
              • 3981
              No. It's otherwise known as the "birth certificate". Every machine is different.
              Memory clear is often what someone unfamiliar with the machine will do to solve any number of problems - including fuser errors! It causes all kinds of undesirable issues, including the one you've shown, and should be considered a LAST RESORT
              The sheet should be inside the front cover underneath the jam removal sheet.
              Good luck!
              EDIT: Ruben beat me to the punch!
              • digicor
                • Jul 2008
                • 1159
                yes i just searched the man hoping for some kinda of default setting's none to be found, I hope someone ran this before they screwed it up,
                thanks
                • teebee1234
                  • Jul 2008
                  • 1670
                  This is not an uncommon issue, it's been addressed on this forum several times and I've seen it myself. The gray balance has reset to factory default.
                  Background when ADS Mode is turned Off
                  In Full Color the background is a process black, In Black and White mode the background is gray. With ADS on there is no evident backgrounding. When ADS is turned off and exposure is at the center setting, backgrounding is exhibited. Print Jobs and internal prints do not have background
                  [Cause]
                  The gray balance adjustment NV RAM Data has been corrupted and has reverted to the default value
                  [Resolution]
                  Reset the value of SP 4685 - 001 and 002, SP4686 - 001 and 002 and SP4687 - 001 and 002 to the value on the Factory Data Sheet.(Located under Jam Instruction Sheet on the Front Cover)
                  If the Factory Data Sheet is not available try starting with these settings and fine tuning as needed.
                  • SP4685-001 to -26 SP4685-002 to -26
                  • SP4686-001 to -6 SP4686-002 to -6
                  • SP4687-001 to -16 SP4687-002 to -16
