ricoh mpc 2500 drum units
  • mrgene
    • 53
    Is there a trick to rebuilding these units with drums and blades from katun (gen) I not having any luck , the drums are getting ate up quickly. I have powder the drums and blades but no luck .
    Any tips.
    thanks
  • skynetto
    • Sep 2012
    • 257
    Re: ricoh mpc 2500 drum units
    Buy the original one for 30 bucks more and no more problems.
    • Zeldaman
      • Mar 2011
      • 946
      Hi there!
      The last time i used a Katun-kit is 16 (or so) years away, and it ended (like most times) in a desaster. Since then i never tried it again. For colour-machines i only use the OEM-parts.
      Greetings...
      • Larhal
        • 584
        Did you check the wax bar inside the drum unit. it is there to lubricate the drum and if it wears out the drum runs dry and will wipe out.
        Larhal
        Larhal
        If all else fails read the Service Manual!
        If that fails, meet me at the pub and we will discuss it.
        • coolbeer
          • Jul 2011
          • 100
          Just buy original black drums and convert to colour.
          Third party units will cost a lot more in time and effort.
          • sandmanmac
            • 3981
            Any tips.
            thanks
            How is it that you've been doing something over and over with the same bad results, and you continue to blame the "process" and not the PRODUCT. It's the product
            As others have suggested, Buy Oem, cut the connector on the Black to fit the colour slot (dozens and dozens of threads about this) and you're done.
            • arnie2002
              Rebuilt units only last a short while. As stated before replace with new units.
              • Eric1968
                • 2458
                Larhal
                The MP C2000/C2500/C3000 doesn't have a wax bar.
                We never use Katun, only the original parts. These machines run perfectly when you perform maintenance on time (with the original parts).
                  • 37532
                  If you are going to rebuild PCUs, you will need to replace the drum, the cleaning blade, the lubricant bar, the lubricant apply brush, the lubricant spreader blade, the charge roller, and the charge cleaning roller. By the time you add in the cost of labor you have just put yourself out of business. Just follow what coolbeer and sandmanmac have suggested.
                  • KapeKopyTek
                    • Nov 2013
                    • 284
                    We use OEM for parts, Katun for supplies. 'nuff said.
                    • fshead
                      • 2376
                      i bought a bunch of katun 1022 b/w drum rebuild kits and found the drums too "soft"..would scratch n mark
                      and figure the rebuild parts for these could be the same supplier to katun..
                      buy OEM,esp on color machines..
