Curling corners and jams in MP 4500
  • jrob416
    • May 2011
    • 112
    [Jamming] Curling corners and jams in MP 4500
    Is there a method for de-curling the leading edge of a page that has been run through the duplex module on a MP4500? It only curls when duplexing and only the corners of the leading edge, causing jams, usually in the finisher when stapling. I have adjusted the fuser heat up and down, with no luck. The fan under the op panel blowing across the fuser exit is operating (that is for de-curl, right?)This has been an on going issue, and is usually corrected by flipping the paper over in the tray, but I was looking for something better to resolve this for our customer. Any help is welcome.
  • Bantams
    • Jun 2012
    • 603
    Re: Curling corners and jams in MP 4500
    Its the paper that's causing it and not the machine you could try installing some Optional tray Heaters if you can get them.
    • mikadonovan
      • May 2008
      • 2931
      You might have to try different/fresh media. I have a ton of these machines that never have had a curling problem.
      NEVER ASSUME ANYTHING
        • 37532
        Paper always has a curl to it. The better the quality of the paper, the less the curl. With your average office supply store, you do not get premium quality paper. If they are always using the same brand of paper, start with a fresh pack of paper. Observe the orientation of the label on the pack. Load the tray and test. Turn the paper over and test. You now should be able to determine which side of the paper is the load this side up side. Instruct the user to always load that side up.
        • Iowatech
          Not a service manager
          • 3930
          Flipping the paper over is one of the most tried and true methods of dealing with somewhat marginal paper, and is really easy, too.
          If you must try something different, try changing the orientation of the paper, sometimes LEF works better or SEF works better, it is up to you to experiment and find out which way actually works. Back in the day loading paper seam side up worked better, but I don't think that's an issue anymore.
          • Dhearn
            • 24
            There was a machine that had to have the paper guides installed at the bridge unit entrance to prevent this prob. Not sure if this is the model or not. Worth checking though
            • Dhearn
              • 24
              Check this attachment out to ser out f it the same machine.
              • jrob416
                • May 2011
                • 112
                Thanks for the image, but it is too small for me to read. The image does not expand when I click on it to read it. What tech bulletin number is this? Thank you.
                • mohan
                  • Oct 2013
                  • 86
                  Some paper manufacturers used to make 'cross-ply' paper with the paper fibres on one side oriented one way and 90 degrees the other way on the other side. This used to work very well as a de-curling method. I wonder why they don't do it anymore. Probably cost, as usual!
