Re: Ricoh 3030 with no toner in Type 1027 PCU...
To check the drum ground you have to use a meter, there are no settings for it. See if there are more than a couple of ohms between the drum drive coupling on the machine to frame ground.
Sounds like like what you tried to adjust was the drum charge setting. I'm not sure, but you might need to press the "*" key before you enter the numerical value. At least some of the machines in this series required that.
