Disable waste toner full message MP5000
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Can't remember the code to disable waste toner near full or find it in the manual, I know I've disabled this message before. If anyone knows it,please share.
    Cheers and Merry Xmas.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
  • hosennet
    • Mar 2007
    • 145
    Re: Disable waste toner full message MP5000
    2960
    Toner Overflow Sensor
    [0 = No, 1= Yes]
    Selects whether or not the toner overflow sensor is activated.
    • jonezy999
      just one copy??
      • Feb 2010
      • 952
      Many thanks bud.
        • 23009
        Just out of curiosity ... you'd rather that the waste toner overflowed, or backed up into the cleaning units? I don't really see the benefit here, unless you're trying to create more work for yourself. =^..^=
          • 37532
          I have always been told that 2960 is a temporary fix for when you have a bad sensor and the customer needs to use the machine while you order in a new sensor. Used to be a problem with 35 and 45 page machines.
            • 23009
            Thanks Slim. =^..^=
            • jonezy999
              just one copy??
              • Feb 2010
              • 952
              The benefit is the machine with a knackered sensor will continue to operate until the new part arrives. Beside that, anyone who has worked on these machines knows that you will have plenty of service calls before the waste toner has filled up again. Only takes a couple of minutes per visit to check/empty the waste anyway , which is part of my minimum call procedure on machines with waste that the customer can not empty.
                • 23009
                Thanks for educating lil' ol' me. I thought this was just a prank on your co-workers. =^..^=
