MP C4000 Process Black Drop out
  • iscott
    • Mar 2010
    • 344
    Have a MP C4000 that black text is dropping out when process black. B&W is fine, and color is fine but text is dropping out...but not every time.
    I have not seen this yet and is per my customer...Pic is attatched...
    • 37491
    Re: MP C4000 Process Black Drop out
    Do you know what kind of paper they wqere using? It looks very much like a fusing problem from using card stock or other thick with a 20# plain paper setting.
    • Eric1968
      • 2458
      This is a paper weight problem. In User Tools set the weight for the tray to the correct value and do the same in the printer driver settings. The paper is moving too fast through the Fusing Unit. The toner hasn't got enough time to fix into the paper.
