MP7500
  • NEOTECH
    • Dec 2010
    • 69
    MP7500
    hi dear good morning i have ricoh mp7500 how can i update firmware , i have firmware but i don't know what is tha procedure.
    what i will do plz anyone give ma idea.
    thanks
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: MP7500
    The firmware update procedure is in the service manual of any machine.
    Hit it.
    • Richariri
      • Dec 2013
      • 163
      Re: MP7500
      Procedure is the same as any other Ricoh multifunction machine.
      I am attaching the relevant part of the service manual for you to use.
      Merry Christmas
      • joshuadenmark
        Re: MP7500
        thanks
        Copy the firmware to a folder named ROMDATA on the SD card.
        From the manual:
        Doing the Software Update Procedure
        An SD card with the software downloaded to it is necessary for this procedure.
        1. Turn the main switch off.
        2. Remove the SD card slot cover [A].
        3. Hold the SD card [B] (the surface with
        printing must be away from the front of
        the machine), and install the SD card
        in Slot C3 [C].
        4. Turn the main power switch on.
        wait until firmware update comes on screen.
        Then select the firmware needed to update and press update.
        Wait until finished, power off the machine and remove the sdcard.
        Done :-) nice weekend to you all!
        • Tonerbomb
          AutoMajical Resolutionist
          • Feb 2005
          • 2589
          Re: MP7500
          RTFM !!! if your new to this or have never done it with a trained tech, don't do it by yourself!! you can hose the machine!!!!!!!!!!!!!
          Mystic Crystal Revelations
          • fshead
            • 2376
            Re: MP7500
            better pull the nic cable b4 doing anything,and i think there is an order wth system and engine to be done
              • 37529
              Re: MP7500
              Also if it has a FAX option, disconnect the phone line.
              • JustManuals
                • Jan 2006
                • 9838
                Re: MP7500
                Paul@justmanuals.com
