Proc651 Drum problem
  • euroc
    • Jun 2025
    problem with my Pro c651ex are lines and dots on my drums after some 2 - 3K printed .I have tried to replace developer units ,developer ,and drums but nothing.
    If someone had I same issue please help. I have some pictures in Attachment.
  • Gamut
    • 216
    Re: Proc651 Drum problem
    have you replaced drum cleaning units, looks like lube bars (very important) and blades on the way out!!
    • qbert69
      • Mar 2013
      • 1152
      Whatever is supposed to be cleaning the drum...brush, cleaning blade, etc. is worn out. Basically the cleaning device is letting the toner slide under it, thus abrading the surface of the drum on each revolution of the drum and dragging the toner particles across the drum surface!
      Check your cleaning unit!
      REACH FOR THE STARS!!!
      Konica Minolta Planetariums!
      • euroc
        Thx ,for fast replies.
        I also thought that the problem was in cl. units but I have replaced all PM parts and still have the same problem. Maybe I should try to replace whole cl.unit as assy.
          • 37413
          you're not using third party toner, are you?
          • euroc
            No , I dont use third party toner.
            • Gamut
              • 216
              Make sure the drum cleaning units are in good condition, replace worn drums and powder/dust them whenever you work in the drum area.
              Those drums are prone to wear/damage through lack of lubrication.
