MPC-305 clutches
  • Zeldaman
    • Mar 2011
    • 946
    MPC-305 clutches
    • 37489
    Re: MPC-305 clutches
    Usually a paper jam indication with no paper jammed in the machine is dust build on the feed roller. Roller spins on the paper but gets no grip.
    • joshuadenmark
      This is nothing, try replacing image transfer lift motor on this model....cruel!
      • jtd55
        • Dec 2013
        • 30
        Looks like my first impressions of the heap are rite if its put in same vain as a Aficio 1224C oh dear.
        Greetings.
        • joshuadenmark
          Remember when there is an extra cassette under, this cassette is blocking so you can't remove the leftmost lower plastic handle at the right side of the PSU, only if you get angry enough....
          I have done a couple of tonerhopper replacements on these 305'er and it's really an ok job, approx 2 hours, but with nice customers and coffee it's not hard, but a lot of screws.
          • slot
            • Jul 2008
            • 341
            silly question but what is tuner spray
            • joshuadenmark
              Hi
              Not silly at all, it's a variant of an Electrical Contact Cleaner Spray, can bring new life into some electrical clutches.
              • JustManuals
                • Jan 2006
                • 9838
                Paul@justmanuals.com
                  • 37489
                  Originally posted by joshuadenmark
                  Hi
                  In the old days for mechanical TV tuners, tuner cleaner usually had a little more pressure than normal contact cleaner and had an extention tube the had holes on the sides. You could insert the tube into one of the ventilation holes of the tuner and clean the entire inside. Hence tuner cleaner.
