first of all hello all im new and very stuck with a ricoh aficio fuser problem
  • suzukigsxr1000
    • Aug 2025
    [Jamming] first of all hello all im new and very stuck with a ricoh aficio fuser problem
    i have a ricoh aficio 3235c which i use for a wide range of projects the problem i have is for some reason the fuser belt has started moving down the rollers to the left and getting jammed so the machine eats it ..
    this is the 3rd time this has happened now and is getting expensive .. could any one help with this before i take my 20lb sledge hammer to the machine in the yard ..
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: first of all hello all im new and very stuck with a ricoh aficio fuser problem
    When this fuser starts eating the belt are you changing just the belt or the entire fuser?
    Hit it.
    • suzukigsxr1000
      hello the first time i changed the belt the second time i got a second hand unit but this was guaranteed 10000 copies but my printer still ate it
      • rthonpm
        • Aug 2007
        • 2859
        Are you using the blue knob on the side of the fuser to remove jams? Are you using the right paper settings, and only using paper made for laser printers? How do the oiler and cleaner rollers look?
        • JustManuals
          • Jan 2006
          • 9838
          Paul@justmanuals.com
          • suzukigsxr1000
            firstly the only thing that has never jammed is the paper all papers and transparent are genuine and printer specifics
            its just the fusing belt slides to the left as you are looking at the printer and gets caught up
            all other rollers look very good
            • Iowatech
              Not a service manager
              • 3930
              Something in the fuser is causing the pressure on the belt to be uneven. Make sure the rollers, springs and bearings associated with the belt are installed correctly.
              Also check that the pressure roller, springs, bearings and linkages are OK.
              Finally, I agree that a new fuser is probably the best way to go on a machine this old. Costly? Sure. But then you shouldn't have to worry about it for a while. New OEM fusers usually have a warrantee, too (make sure to ask about that, though).
              • Navy
                Brown Shoe Sailor
                • Jul 2006
                • 47
                Is the machine on a solid level surface?
                NAVY - Never Again Volunteer Yourself
                • suzukigsxr1000
                  • Amos Kaplan
                    • Nov 2013
                    • 9
                    There are spring loaded bushings that support a white felt roller (Cotton looking) that keeps the tension on the fusing belt. When those bushings wear out, it can cause the belt to walk.
                    Here's the pn#'s to the bushings and springs (2)AA06-3426 and (2)AE03-1039
                    Amos
                    • suzukigsxr1000
                      Amos
                      thanks amos
