sc 990 in ricoh 2035
  • vargue
    • Oct 2011
    • 404
    [Misc] sc 990 in ricoh 2035
    i went to customer had this code .i met this before and no problem solved .but in this case i need help. i changed drum . and unplugged hd and ram machine working about 200 papers . then appeared agian. in the next visit i did common rest. and machine after 400 pp apeared again. the last thing .in this fucking machine. i will do clean switches .any suggestion
  • ruben
    The New Guy
    • Oct 2012
    • 1203
    Re: sc 990 in ricoh 2035
    SC990 is a generic software error, which could be anything, anywhere and at anytime. Trying to fix them is a futile task, I just ignore them unless they are appearing to the customer. Make sure that the firmware is up to date then pray it doesn't happen again.
    • JustManuals
      • Jan 2006
      • 9838
      Paul@justmanuals.com
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        clean the machine!!! may need to do full pm with drum and developer. Many times I've gone out to a machine a tech could'nt resolve sc990, and found it to be a dirty pig.
        Like the hat ruben!! very festive!
        Mystic Crystal Revelations
          • 37489
          Tonerbomb is correct about needing to do a full PM. See the TSG for the 2035e attached.B135_TSG rfg014203.pdf
          • KapeKopyTek
            • Nov 2013
            • 284
            Just ran into this today on a 4045 WITH 776K. PM parts on order......
            • gear13z
              • Sep 2011
              • 68
              i have this one once, i just replaced the developer, and clean the gear on the front area of development, lucky the sc code didnt comeback.
              .....with all it shams, drudgery, and broken dreams, it is still a beautiful world.....
              • cdog530
                • Nov 2009
                • 66
                Worn out drum and dev.
