ricoh mp2550
  • Luther
    • May 2006
    • 682
    ricoh mp2550
    I have a problem with the preset stamps , when you select stamps on the display all the stamps show but the preset stamps, they arent highlighted and cant be selected....i looked thru all the sp codes to see if they can be turned off/on but cant seem to find anything...anyone see this before? any help is appreciated
  • sandmanmac
    • 3981
    Re: ricoh mp2550
    SP5853 (Stamp data download).
    If the HDD has been replaced, and this hasn't been done, that explains why they're not available.
    Cycle machine off/on afterwards.
    • Luther
      • May 2006
      • 682
      Re: ricoh mp2550
      thanks ill give it a try on monday
      • Luther
        • May 2006
        • 682
        Re: ricoh mp2550
        thanks that was it, i bought this machine from a wholesaler so i dont know what they did..another question, the yellow light on the nic card stays solid, when i connect it it stays yellow..i input the ip and try to ping it but nothing, i can print usb without a problem, does the nic have to be reset if the did repalce the hard drive?
        • sandmanmac
          • 3981
          Re: ricoh mp2550
          NIC does not have to be reset due to a new HDD, but it may have been disabled OR never enabled on that machine:
          SP5985-001 On board NIC (O=off /1=On)
          SP5985-002 On Board USB (0=off / 1=On)
          Edit:
          Now that i think about it, I don't think that the light would on the Nic would be lit if it wasn't enabled. But maybe worth a try.
          • Iowatech
            Not a service manager
            • 3930
            Re: ricoh mp2550
            The NIC shouldn't need to be reset if the hard drive was replaced.
            You might try entering a new static IP address in the machine and try pinging it then. If it isn't a static IP address, your network might be changing it before you get to ping the machine.
            To the best of my knowledge, the yellow light on the machine's NIC is supposed to stay on all the time.
              • 37533
              Re: ricoh mp2550
              All the time that it is connected to a network. If it is on with the cable disconnected, there is a problem with the controller board. Try setting for Auto Assign (DHCP) and see if ypu get an IP address. If you do, check the sub net, gateway, and DNS settings from the DCHP.
              • Luther
                • May 2006
                • 682
                Re: ricoh mp2550
                i tried a static ip with my laptop with a crossover and the same thing...also tried auto assign and get an ip of .011.022.033.044... the light never changes.even with the network cable unplugged and the green light never comes on
                • Zeldaman
                  • Mar 2011
                  • 946
                  • babar123
                    Re: ricoh mp2550
                    Dear Friends
                    I facing lots of problem in RICOH MP2550, Ist: I changed all the parts on the machine including developer type28, after that round about 1000 copies the print quality light , It's seems like toner is not feed properly and also one thing more is coming in back side there's some black shade coming . I service drum unit but the problem coming again same. I have three machines in customer place, all the machines same problems. Ist machine i taken 74000 copier and I changed four developer on this machine 2nd machine I take 50000 copier and I changed three developer. and the third machine only get 10000 and used one developer ( because this machine used as a backup ) ... my question is that why print is coming light and black shade is coming in back side ., If am not changed the developer the copy coming more dark the print quality very bad . Please suggest me
                    • rthonpm
                      • Aug 2007
                      • 2859
                      Re: ricoh mp2550
                      Originally posted by babar123
                      Dear Friends
                      Instead of digging up an old thread with no relation to your problem at all, create a new one.
