Mpc 6501 error only on print
  • digicor
    • Jul 2008
    • 1159
    The mpc6501 has functional problems only when a print job is sent to it, not when copying
    could this be a corrupt print driver?
  • Eric1968
    • 2458
    Re: Mpc 6501 error only on print
    Are there any SC's logged in SC-History? Could also be bad or corrupt data in the print jobs.
    • ruben
      The New Guy
      • Oct 2012
      • 1204
      Ricoh are plagued by corrupt PCL and PS jobs causing SC errors, if you see a lot of SC899 or 9xx in the logging data then you have a corrupt print job in the queue. Updating the firmware is all you can do, if it still occurs you could send a capture of the print to Ricoh for analysis.
      • Tonerbomb
        AutoMajical Resolutionist
        • Feb 2005
        • 2589
        There was an issue with a recent version of acrobat reader causing sc 899 on Ricoh boxes, I think it was 11.22.xx. Google it thats where I found it.
        Mystic Crystal Revelations
        • digicor
          • Jul 2008
          • 1159
          thanks but now ive found out it does it on copy as well, is the corrupt prnt job the cause still?
          im replacing the prnt controller today but if its in the copy as well im not sure this will fix it
          ill check the job log.
          • TonerMunkeh
            Professional Moron
            • 3865
            I'm pretty sure replacing the controller will make no difference. Go into SP modes and check what SC codes have been registered when the functional restart occurs. It will probably be something to do with process control.
            Hit it.
            • digicor
              • Jul 2008
              • 1159
              thanks for the heads up,
              • turbojetboy
                • Aug 2009
                • 279
                If it's showing functional error on screen with a series of slow moving dots before it finally restarts, my money is on the itb assy. Most likely you will need to dissasemble and clean out unit, replace belt and you may even have to PM the pcus. The SMC report should give away the sc code related to the error. You just cant take any shortcuts with these machines, everything needs to be spot on for them to be reliable.
                • teebee1234
                  • Jul 2008
                  • 1670
                  Many SC899 codes that only come up when printing are due to printing from a web page that has a URL longer than 63 characters. It's a bug that has been addressed recently with new firmware across multiple models, so make sure that you have the latest. That last 2 calls I had for this was when the user was printing a brochure from a Verizon web page (http://verizon.com/......./.../brochure). One account was a Verizon office, the other a law office. Another tech experienced this when the user was printing from a particular Comerica web page.
                    • 37605
                    There is a SP setting to force it to show the SC instead of doing the restart count down.
                    • digicor
                      • Jul 2008
                      • 1159
                      which one is it?
                        • 37605
                        Originally posted by digicor
                        which one is it?
                        SP 5875-001 SC Auto Reboot. Set to 1 to display SC.
                        • digicor
                          • Jul 2008
                          • 1159
                          Now this machine has a error
                          sc 876-05 nvram or hd bad....
                          Can i do a hd format and clear this up? i dont think the nvram would just go bad but you never know
                          Im having this machine replaced if this cant be dealt with.
                          oh and thanks
                          • its_just_a_copier
                            • May 2011
                            • 132
                            SC899 has been mentioned quite a lot in the firmware updates so make sure its up to date.
                            Also format your HDD SP5832-001. This has fixed many SC899s (Before doing this make sure your address book is backed up)
                            • its_just_a_copier
                              • May 2011
                              • 132
                              which one is it?
                              SP5875 Auto Reboot Setting
                              Set to 1
