ricoh 6513 - no power
  • bmartin
    I have a 6513 with no power
    I have 110 volts to both the AC drive board and the PSU
    I cannot find fuse FU301
    I do not have 5v at CN13-1
    We had a service tech out a while back. Before he arrived, the machine would at least power up and display codes, but not after he left.
    Can anyone help ??
  • iMind
    Vacuum Cleaning Expert
    • Mar 2008
    • 1116
    Can anyone help ??
    I would try taking out the fuser unit and then power uo the machine. I say this because theres lots of cabling on the rear end of the fuser, maybe some one trapped with a gear.
    • ZeusGT
      • 271
      What connection does CN13-1 control?
      What kind of codes was the machine displaying?
      CompTia A+ Certified
      CompTia Net+ Certified
      CompTia Server+ Certified
      CompTia Project+ Certified
      OP Scanshare Certified
      • schooltech
        School District Tech
        • Jun 2008
        • 504
        I had one that acted similar (with power present but acted somewhat dead) and it ended up being the NVRAM.
        It took us quite a while to diagnose this. Once it was replaced, the machine fired up. But, it required a trip from the regional service tech to input in the serial #, etc.
        Also, I wonder if there is a pinched wire somewhere that is shorting out.
        Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
        • pspahr
          Toner Schlep
          • May 2008
          • 227
          Can anyone help ??
          Take this as an opportunity to upgrade the customer (sorry, couldn't help myself)
          VectorLinux---Check it out!
          • nmfaxman
            • 1702
            Call the tech back or call another company.
            If you don't have the P2P schematic leave it to a trained tech.
            I don't have meter leads long enough to troubleshoot your problem.
            • bmartin
              update:
              I have the p2p schematic
              What I need is the schematic for the power supply board.
              5ohm resistor R5 is open, no fuses blown
              I have disconnected all output circuits from the power supply board, and it still cooks R5.
              none of the components on the board are testing shorted
              any help is appreciated
              • iMind
                • Mar 2008
                • 1116
                update:
                Ricoh has no power supply schematic,only point to point.
                • Fearless V K
                  • 620
                  V=IR, P=IV, ELI the ICE man, etc. good luck and try not to accidentally discharge a 1000uf cap with your meter (don't wear a ground strap!).
                  Personally, I find component level troubleshooting intriguing (sp?), but my time is worth more than the cost of the PSU.
                  Don't take that toner with me!
