Ricoh Aficio 2035
  • tcypy1961
    • 773
    Ricoh Aficio 2035
    What would cause paper being fed L.E.F. to bend the lead edge corner down? I know that it was sticking on the heat roller, and decided it was best to replace both rollers. However, after replacing them, the problem persists. I decreased the fuser temperature and it seemed to help but there is still some minor bending. Prior to servicing the problem the folding would cause the paper to stop before exiting the machine. Thank you for any help given.
  • rthonpm
    • Aug 2007
    • 2859
    Re: Ricoh Aficio 2035
    When you replaced the heat tube and press roller, did you also replace the pickoff pawls (aka fuser fingers)? It sounds like you've got a build up of toner on one of them, or the tensioner spring has gotten too loose. Either way, doesn't a new heat tube deserve new fingers?
    • Zaxxon
      • 608
      It could also be a paper problem, to moist/wet paper can cause this.
      Please start you post with brand, model, problem.
      • Athlontini
        • Jun 2012
        • 269
        And if this is only happening with LEF, then you've ruled out all but probably the leftmost or rightmost pickoff.
        • teebee1234
          • Jul 2008
          • 1670
          Is it a bend with a crease or just a general curl? If it's catching on a stripper or something, you should see a nick at that point. It's normal for paper to curl to some level when fed LEF because the grain is perpendicular to the paper travel. As stated by Zaxxon, moist/damp paper will curl more but also paper that comes off the roll close to the core when manufactured will curl more than that which is cut from the outer diameter.
          Also, is there a finisher attached? If so, have you tried removing it to see if the problem is occurring before it exits the copier or in the finisher?
          • Bicyclerepairman
            • 63
            If it's only bent over & not folded flat, problem is occuring after exiting rollers. Look for toner buildup or stripper fingers condition. You could always flip paper over to check if it's paper curl.
            • tcypy1961
              • 773
              It is the corner of the page closest to the front side of copier. where it is curling down is in the area where no sep claw is at...
              • Zaxxon
                • 608
                A good idea is to clean all guides firmly, they can get rather sticky.
                check for toner build up and deformation/scratches.
                Check paper position in the cassette.
                • Butrus
                  • Jan 2012
                  • 115
                  Make one copy and deliberately open front door before paper exits
                  You are able to closely pinpoint the area where the fold occours
                  Sometimes its the small litle piece of paper stuck in a corner somewhere
