Ricoh MP 1600 SC-551 reset
  • jonbonse
    • Jun 2009
    • 737
    Hi all
    How can I reset the SC-551 code on a MP1600?
    Cant find SC reset anywhere in Service mode!
  • Bantams
    • Jun 2012
    • 603
    Re: Ricoh MP 1600 SC-551 reset
    SP 5-810 you do know how to enter SP mode right?
    • rthonpm
      • Aug 2007
      • 2859
      Try just going into Service Mode and restarting the machine from there.
      • jonbonse
        • Jun 2009
        • 737
        Thanks guys
        Yes I've already tried that!
        New thermistors and thermostats installed too!
        • jonbonse
          • Jun 2009
          • 737
          Also, there is no SP5-810!
          • idar@kontor.as
            Try holding # when you enter copy SP/system SP
            • Bantams
              • Jun 2012
              • 603
              try entering service mode for engineers C/A 107 C/S and there is a SP 5-810 its in the manual in front of me
              • Bantams
                • Jun 2012
                • 603
                Well ya learns something new everyday didn't even realise myself till now but theres 2 SP modes on these the standard one and the special one
                the special one is the one you need
                Starting SSP Mode
                For the basic machine (the machine without the optional controller box), perform as listed in
                steps 1 through 4. For the GDI machine (the machine with the optional controller box),
                perform as listed in steps 1 through 5.
                1. Type the keys as follows: [Clear Modes] > [1] > [0] > [7]
                2. Press the key and hold it down until the SP-mode menu shows (about 3
                seconds).
                3. Press the [Enter] key and hold it down.
                4. While holding down the [Enter] key, press the [1] key (on the numeric
                keypad).
                5. While holding down the [Enter] key, press the "OK" key.
                • 3bok3bok68
                  Senior MFP Technician
                  • Nov 2008
                  • 56
                  Access SP mode then turn off and on main switch..
                  • jonbonse
                    • Jun 2009
                    • 737
                    Starting SSP Mode
                    seconds).
                    keypad).
                    Thanks!
                    Not sure which is the enter key as ive never seen one on a Ricoh machine unless it's the '#'?
                    • jonbonse
                      • Jun 2009
                      • 737
                      Already tried that one
                      • Bantams
                        • Jun 2012
                        • 603
                        yes the enter key is # on ricohs you press it after getting to the sp mode screen via the usually ca 107 cs
                        • Athlontini
                          • Jun 2012
                          • 269
                          In that case you might want to double-check your thermistor connectors or the PSU, because if you can't find SP5810 (I can't remember if this series even had it), then you've reset the code and something is still wrong with the machine and causing it to reappear.
                            • 37533
                            Per the SM, enter SP mode and then turn the main power off. After trying clearing the error code, restart the MFP with the front door open. If the code is still there, it was not cleared and you have a board problem. If there is an uncorrected problem, it will not code again with the door open. Enter SP mode and check reading on rear thermistor. At room temperature, I usually see a reading in the range of 20 to 30. If you have a reading of 0, either the thermistor is open, there is an open in the wiring, or the power supply board is bad.
