Pro c901 dead
  • mrfuser
    • 1622
    Pro c901 dead
    Client has a c901 that just died on warm up. Completely dead no power. We replaced power supply and still dead. Could this be bad IOB board?
    kelly
  • JustManuals
    • Jan 2006
    • 9838
    Re: Pro c901 dead
    Paul@justmanuals.com
    • Tonerbomb
      AutoMajical Resolutionist
      • Feb 2005
      • 2589
      Re: Pro c901 dead
      kelly
      There is more than 1 PSU in the C901 ! Have you tried the basic disconnect ALL ACCESSORIES and try to boot up?? Pull the fuser out, Open the front door and boot? check psu out puts with a meter? any LED's lit up on PCB's?? Was there any service done right before this occured?? Yes it could be the I/O but I would do more checking Before replacing the IOB or any other PCB's.
      Mystic Crystal Revelations
      • incognegro
        • Feb 2013
        • 20
        Re: Pro c901 dead
        kelly
        Behind the machine there are two IO boards at the bottom. IOB has a connector on the back that doesn't go all the way in if you just press it in and bolt it in. You have to remove both IOB boards and push the connector towards the board.
        I replaced the IOB2 board and had a blank screen, but if you squint you could just barely see a SC601 on the screen.
        Also, check the breakers, obviously.
