MPC2800 style charge rollers, who else cleans them?
Re: MPC2800 style charge rollers, who else cleans them?
i use scotchbrite and alcohol and rub the top coat off tills its pale.
of course ricoh would not advise you to do this as well as modifying the black drums to color.
its always about the $$$$$Comment
Removing the cleaning roller is the key to getting it to work. I use scotchbrite and alcohol to take the coating off, ensure it's completely clean and dry, and it really does workThere are 10 types of people in this world, those who understand binary maths and those who don'tComment
On the color machines i do the same we use the Nu-Finish, we also use the wax on cleaning blades and drums for all B&W machines that the pcu comes part instead of using the powder, however on the B&W machines if the charge roller gets dirty i use soap and water in a sink to clean them, pretty much do that as a first attempt if i get called back within a week or two for the same problem i replace the pcu on the color machines. I dont like coming back a 3rd time.Comment
the same kind of roller is used in MP C7500, well i did clean it eventually removing the gray-ish coating, but it doesn't work any more. Clear me if i 'm wrong here, i have read the entire thread, do any of you suggest that removing charge roller cleaners can make it work? please reply ASAP coz i 'm kind off in a middle of this thing.Comment
brillo pad that seems a little much I just use a cotton rag and alcohol it works fine
Only remove the charge roller cleaning roller or place paper between the charge roller and cleaning roller to keep the cleaning roller from getting damp while cleaning the charge roller. Reinstall it after the charge roller is completely dry. If the cleaning roller is damaged, it is time to replace.Comment
