Gestetner 3235e
  • Machelle
    • Aug 2025
    Gestetner 3235e
    Gestetner 3235e says cover door open and wrench light is on. How do I turn off wrench. Cover door is closed and door sensor seems to be working. It also has error code SC320
  • bilyahn
    • Dec 2006
    • 1470
    Your error code has to do with the polygon motor in the laser unit. You can try to reset it by pressing "clear modes", 1, 0, 7, hold down the stop button for 3 sec. Enter the copy mode simulation then turn your machine off and on. If it doesn't reset then you have an issue with your laser unit!
    Good luck!
    • nmfaxman
      • 1702
      Unplug the machine and plug it back in.
      If that doesn't work your polygon motor is locked up.
      Call a tech.
      • Jomama46
        • 2900
        Yep, needs a PM motor. That close door can be any of a dozen of those little push switches. Most can be eliminated by using the input checks tho.
        sigpic
        A+; Network +; PDI+
        • Machelle
          Thanks this information helped a lot.
